White Nuckles
Mobil Primestar
Opinion of Montana Fiver
On my way thru Nebraska in Feb. while towing my 28' TT loaded I hit black ice and ended up turning my steering wheel 6 times 90 degrees right to left from center total of 180 degrees. All of sudden there were semis, passenger cars and vans rolled and ditched everywhere. I quess blind luck worked in my favor and I managed to stay on track. It could of gone the other way just as easy. Some of those trucks never slowed down. I've been on black ice once before and it is some scary S**t. Especialy with the TT.
2001 2500 tow, camper, SWB, ETH/DEE, 3. 54 Bright white,4 wheel discs.
Glad to hear you made it through okay, Walter. Be careful.
2001 2500; SLT; 4x4; QC; LWB; Auto; 3. 54 LS; 265s; Camper; Tow; Sliding Rear Window; Travel Convenience Group; Cab Clearance Lamps; BedRug; Forest Green
Old trucker trick,keep a gallon or two of Clorox in the rig. If you run into black ice and absolutly have to get into the next town pull over and pour over the tires. It will give you enough traction(softens rubber) to get to the next town. Do not however pour it on and run down dry highway. It will put some undo wear on your tires. When temps drop and fog hits,keep an eye on road color and surrounding vegetation. Or pull over and check road surface. I stepped out of my rig one time and fell on my butt. I had been driving on ice for awhile. Luckily I didn't need to stop quick.
95 Dodge 2500 Luverne grill guard,headache rack,running boards and Amzoiled. Soon to be mildly bombed. 84 Dodge d-150, 318 Hooker headers,Edelbrok intake,mallory ignition,Carter Afb,Accel coil,and Custom dual exhaust. Boat,fifthwheel,motorcycles,and shop. 72000 as of 3/1/01,not even broke in yet. Old Dodge 126000 miles and running better than new.
Was glad to see the clorox bleach info. My grandpa and my parents have done that for years. Grandpa said a guy who owned a private ambulance service used bleach on his tires to get people to the hospital when there was ice on the roads. I'd tell people that and they would look at me like I'm crazy. It works. Thanks for the validation.
Walter, sounds like your driving skills were up to par,I bet you was glad to get thru that one #ad
Another trick to do when getting squirly on the slick stuff is to strech the rig out by gently putting a little brake on the trailer, but not the truck, in WYO in the winter this has helped me out many many times. Kevin
2001 eth dee,qc,lwb,3. 55,camper and tow pkg,driftwood,cummins e-brake,jardine 4" exhaust,dz alum checker run boards,bed rail,tailgate protector,better built alum checker toolbox with home made fuel tank under box,"CUMN" licence plates and captain vol fire dept plate too
Another old trick. Gotta window in your car that fogs all the time?Take a raw onion slice it in half,put in in a old dishcloth and rub it on your window. In most cases it will stop the fog.
