Now that the weather is turning a little colder here in Michigan, especially in the mornings, I am getting tons of white smoke on startup and driving thru the gears. Excelleration is non existent because of all the stumbling and hesitation. However once it warms up to normal operating temps everything is fine and runs great. My setup consists of 370 injectors and lower compression pistons with a thicker than stock HG. Is this just the nature of the beast having 370s and lower compression in cold weather?? I am assuming it is but is there anything I can do to help the problem?? Oh yeah I have the intake heaters on a manual push button switch so that might add to the problem some too. Any advice?
Thanks,
Chad
Thanks,
Chad
