i assume he is responding to the coment about being way nicer than all the other kits out there.
gary, like someone else said, i fit 35" tires on my truck stock. i doesnt look the best but i have the clearance i need. a level kit is all you really need but with the stock wheels your tires will probably rub the arms. i would say make your decision based on how you use the truck. if your offroad at high speeds, drop the big bucks on a race set up. if its just a driver, lift is as high as you want. just keep your towing needs in mind. i work outa my truck so i choose to keep the rear at stock hight. i dont enjoy climbing in and out and another 4" would just irritate me. (considering the axles arent getting any higher so clearance is not gained. ) i also like the simplicity of a level kit or small lift. keeps the truck closer to where those high paid engineers designed it be.
good luck to ya.
