Competition Who makes the most Power (drag racing)
Competition 11sec 24V w/o drugs
Competition P pumping a 24 valve
Since the mods want banter... ... Who makes the most power? Not fastest ET, because we all know what a 650 hp motor in a 2900 lb truck will do... ... .
On Edit:
If we were to take this motor, and slap it in Fletch's truck, Comps ride, Scott or er Erics' rail, RD's dually, or Keatings truck, would they go faster?
RD's dually needs more than 650 hp and I am FAR from 2900lbs! I'm more closer to 8000lbs- I wish I could be 2900lbs... ... :rolleyes: What you trying to start here ?:-laf :-laf You bad man!
On Edit:
What motor ? to contribute to this dialogue, respectfully speaking, If you were to take my motor and put it into
“Part-Times” truck, It would finally make its' first ten sec run .
If you were to put my motor in “Shed Putters” truck, it would accelerate his ranking from “Has been” to “Da Man”
If you were to put my motor in the “BS” truck, he could loose the drugs and relieve his large twin fabrication frustrations plus,the G-force would rip those flames off.
Just trying to add some illustration, examples to this inquiry. .
(Please note: the author is a peaceful, passive Amish person. If any offense is regarded from this depiction the author will immediately revise the context)
Maybe from "Has been" to "Wanna Be" but "Da Man"????? Wow, is there even enough collective knowledge in the diesel performance business to pull that miracle off?
Sleddy wake up & join the party.
Fletcher said:
If you were to put my motor in “Shed Putters” truck, it would accelerate his ranking from “Has been” to “Da Man”QUOTE]
SO... . I knew it... ... there is no difference between a drag racing motor and a sled pulling motor. Comp, you listeneing. Fletch said it, so it must be true.
The only difference between Drag racing or pulling is the hitch, Drag racers have bigger hitches, dats iz cuz thas gos fasthers. Sitz, i anits gots sum da fidgeator fetc 40 oz-ser :eek:
And how fast dose your truck go??????
We don’t race dyno’s numbers …. The number on the score board is the only one that counts, and it’s the real printed number not the altitude factored concoction . For the few of you that don’t understand what I’m talking about , when you run in higher elevations and run a given time , there is a factor that tells you what you would have run at sea level on a standard day . this is not a real number , and surely isn’t in a diesel ,where we make our own atmosphere. But some people want to clam this as a record, when in fact they have never been in the 10 second range.
Jim for all the help you have given, you can borrow a set of slicks any time
the person I'm talking about is Maddog , come on show us a time slip. don't tell me you don't have it , I have every time slip I have ever run . even have one that is faster then my record , but it was done on a Monday after the national event with only 50 people there, during a private test session. So I don’t count it
So a pass doesnt count, even if you have the timeslip, if nobody was around to see it?
If a truck breaks a record whlie a tree falls in the woods, do the school bells still ring on the weekend? :-laf :-laf :-laf :-laf
On Edit:
IMO - based on what I have seen with my own eyes, Keating Machine, so far...
I just heard that the levee's broke for the Mississippi River just breached... ... .
Best and safe wishes for the members in that area getting hit... ... .....
