Originally posted by Loren
There is a delay after selecting the brake ON or OFF before the brake actually closes or opens. The new master controller delays even longer than the original one before actuating the brake. It’s probably two seconds from the time I switch the brake to ON before the brake actually closes. The same delay occurs when the brake is selected to OFF. This is more than a nuisance, it’s sometimes a hazard. I don’t know why a delay is programmed at all, unless its to allow time for shifting gears without affecting the position of the brake. I don’t like it, but I can’t change it.
I’d consider a different brand, just because of the costs involved with repairs for the U. S. Gear.
Loren
Loren,
Sorry to hear of your troubles with your USG. I have one of their original superduty models (old controller and wireless remote on-off). There is a way you can bypass the controller and have instant open/close, thought I am not sure I would advise it unless you get at least a half a second delay worked in. PM me if you are interested.
USG is helpful in answering questions, but my experience has taught me that they have no desire to meet/work with anyone on the repair/replacement part cost. I was quoted $324 for a replacement solenoid, and the same $ as you for a replacement control box. I got the unit second hand, and no installation instructions. No-one at USG remembered how it was wired, so their solution was upgrade to current model. Took them two weeks to find the original model instructions after I said "No way am I spending that much more than I have already"
I have had a few problems with mine as well, but all mine were self inflicted. I did not like the supplied throttle switch so I made my own, and I also wanted one on the clutch. I have also installed a momentary on switch on my shifter so I can activate the e-brake at will when coasting (city traffic, and downhill runs with no load).
IMO, the in line is a better choice to go with.
1. If you go to a larger turbo, you don't have to replace the e-brake.
2. One less thing under the hood to deal with.
3. Less weight hanging directly off the exhaust manifold.
If you go with an in line, get the largest (4" at least) opening that you can.
