Goin' down the road and the truck just completly stops responding to accelerator input. Then springs back to life and cuts in and out then is fine for a day or two. I pulled codes today and have the usual 1693 as there is a host of codes as follows with a MIL mind you:
<hr>
P0753 (M) Trans 3-4 Shift Sol/Trans Relay
Circuits
An open or shorted condition detected in the overdrive
solenoid control circuit or Trans Relay Circuit in JTEC RE
transmissions. Was MIL code 45.
Circuits
An open or shorted condition detected in the transmission
2-4 shift solenoid circuit (4-speed auto. trans. only).
P0743 (M) Torque Converter Clutch Solenoid/
Trans Relay Circuits
An open or shorted condition detected in the torque
converter clutch (part throttle unlock) solenoid control
circuit. Shift solenoid C electrical fault - Aisin transmission
converter part throttle unlock solenoid control circuit (3 or
P1765 (M) Trans 12 Volt Supply Relay CTRL
Circuit
An open or shorted condition is detected in the
Transmission Relay control circuit. This relay supplies
power to the TCC
P1765 (M) Trans 12 Volt Supply Relay Ctrl
Circuit
Current state of solenoid output port is different than
expected (4-speed auto. trans. only).
<hr>
Some Trans mods can lead to a 743 from the use of a smart controller?
But why no codes from the ECM? If I remember right the codes used to cycle PXXX Pxxx PDone Exxx Exxx EDone or am I remembering something that never was.
The reason I ask is Why the ZERO input from the pedal?
Check my Profile or Here for mods , It shoulda set a code ... . ESPECIALLY with a MIL lit up like a charm.
<hr>
Circuits
Circuits
Circuit
power to the TCC
Circuit
<hr>
