Engine/Transmission (1998.5 - 2002) Whos Making The Most HP/TQ On a 24V With Out Electronics
Engine/Transmission (1998.5 - 2002) 100,000 and 0216 code same day
Engine/Transmission (1998.5 - 2002) Pump cover????
I think a "Killer B2"(64/14) HTB2 from HTTurbo would be a perfect match with just the injectors and that ADD. My truck ran great with that setup, very streetable, yet pretty smokey when you really get in the "go" pedal.
Wasnt it Bob Wagner that made 401HP w/ Mach 4's, Dodgezilla, and a Smarty? Seems pretty sweet & simple. No tap wire.
DieselMinded said:
I heard about this Dodgezilla they anygood ???
The DZ is a heck of a spinner for the price. I used one on my '01. 5 ETH with Don's Mach 3. 8's & a Blue Chip APB. Just a slight haze at WOT & I never saw 1300* egt. I'm not towing heavy in the mountains though.
Yes. . For the price, it is a great charger. I've been running one now for quite some time now in my daily driver/towing set-up and I can't say enough good things about it.
I've had a much bigger single in a box waiting to go on for quite some time now. But, my current combo is so well rounded, I keep talking myself out of getting rid of it.
DieselMinded said:
My stciks run 600 * 55-60 on cruise and only just barly past 1000* WOT on it hard... . a maginal charger should clean me up a little ?
DM
It doesn't seem like you need a bigger spinner to me. You aren't over heating with a stock charger. Are you pulling 35psi of boost? You could do a little port matching & try a 14 cm turbo housing if you want to cool it a little more.
For being big sticks they do run cool I need to get my other problem fixed before i think about a charger ..... The truck bout' dies going into gear
DM
