OK, I'm really thinking of repowering a 4x4 Crew Cab Chevy. I have a Complete 92 W250 5 sp that has already been converted to an AA NV4500. I've talked to Autoworld before, and they say they place the motor set back, you just have to trim/dimple the forewall a bit, and they give you a template to notch and box the front crossmember. Has anyone on here used their stuff, and does it work as good as it sounds? Also, I had a question about Hydroboost brakes. The Crew Cab I'm thinking of doing it on I think has hydroboost brakes, my Cummins has a vacuum pump. Will a 97-98 steering pump bolt right up and run the GM hydroboost w/ no problems? Thanks
