Originally posted by rbattelle
Actually, diesel fuel has less energy content than gasoline. Check out the lower heating values, it's true!
Beware Hohn's second post is talking about thermal efficiency, which has no effect on power or torque... only on fuel economy. The ideal efficiency (or Carnot efficiency) of any cycle operating between two thermal reservoirs is 1 minus the ratio of cold-to-hot temperature. It is the absolute maximum achievable thermal efficiency of a perfectly reversible cycle. A common metric for determining how thermally efficient your cycle is, is to compare it's real thermal efficiency with that of it's Carnot efficiency.
As Hohn points out, if we can cool the cold reservoir or heat the hot reservoir the Carnot efficiency will increase, thereby allowing a well-designed engine to operate more efficiently and use less fuel for the same power output.
God I love these technical threads.
Thermal efficiency DOES have an effect on output. But, only IF you keep the fueling level the same. More efficiency, more output. You get better mileage simply because you are using LESS of the potential output than you were before. It's a chicken or the egg kind of thing. Your second post on this is accurate, AFAIK. Think of it like a muscle: a muscle that is capable of lifting 300 pounds is far more efficient at lifting 50 pounds than one that is maxing out at 50. Especially if they are using the same level of "fuel" to lift their respective maxes (300 pounds and 50 pounds).
I am not sure if you are correcting me (take a number since i am wrong a lot!), but I can't see anything i said that was untrue. Joe Donnelly explained the heating values for us (VOLUME, not MASS), so for our purposes, diesel does have a higher heating value- though I was not the person to state so.
As you said, it is the diesel ENGINE that is more efficient, not the diesel FUEL, per se. The Fuel itself DOES have some advantages in that is has larger molecules, on average, in its mixture of hydrocarbons, i. e. longer HC chains. More bonds= more potential energy. Along with these larger molecules, density (or, for rbatelle, specific gravity) increases. In fact, it increases faster than the heating value does, thus you have lower heating values when measured BY MASS. Not true by volume.
As for Joe's comment about gears, it's like I said: HP is composed of the tq and time elements. Gears trade one for the other. That's why you can multiply torque, but not HP.
My Thermo education is no doubt NOT as extensive as some other people's is, so let me ask the question:
What is cut-off ratio? I never heard of that. All this thermo stuff so far I am just extrapolating from my turbine engine theory class. i don't recall ever hearing of a cutoff ratio! I do remember Carnot and all that other jazz.
Leave it to the TDR to teach me something new every day!
Thanks, fellas!
HOHN
