Bought a new set of Toyo's from Schwabs about 11000 miles ago. Supposed to be their best tire. When I took it in for rotation, there was noticeable uneven wear (cupping) on the outside of both front tires. Had the alignment checked and it was ok. Put new shocks on also. Now, 3000 miles later, the tires are still wearing the same. Cupping on outside of both fronts. Got an appointment to take it back for front end check, but don't have a lot of confidence. Any ideas I can point them to. It does have a slight pull to the right. If it were alignment, would both tires wear on the outside.
