THE above by HVAC pretty much illustrates MY point - better than 2/3 of fuel requirements for the 24 valve are NOT for operating the ENGINE, but to cool the VP44... That cooling requires a decent flow RATE, not necessarily PRESSURE...
And as HVAC states, losses in flow RATE created by various restrictions, fuel filter obstructions, etc. , ALL contribute to compromize the flow rate the VP44 needs for cooling, over and above engine needs.
Decent PRESSURE to the VP44 can be rather easily obtained down at the levels needed for engine power only, and various fuel line obstructions contribute rather little at that rate of flow - but when you add in the FLOW RATES needed to cool the pump too, those obstructions begin to be a very real problem!
And as a few here have discovered the HARD way, supplying TOO MUCH flow and pressure to cover line losses at MAXIMUM system demands can SOMETIMES overpower VP44 seals at lower engine demands, creating yet ANOTHER problem and VP44 failures!
Trying to overcome fuel line obstructions merely by increasing pressure and flow from a second pump MAY get the job done, but eliminating as many of the obstructions as possible isn't a bad idea either...
