Engine/Transmission (1998.5 - 2002) Why Banjo Bolts???
Engine/Transmission (1998.5 - 2002) Loss of Power
Engine/Transmission (1998.5 - 2002) After trans fluid change oddities?
"The 30 gph spec for the VP44 is a low end spec. More volume is better as long as the max psi @ the inlet is around 17 psi. More fuel = more cooling capability. "
According to the tests (several of them!) in the thread pointed to further above, 30 gph was the absolute MAXIMUM they could get thru the VP44 under ANY circumstances or load (at reasonable VP44 inlet pressures) - and considerably LESS at lower demand...
The setup I am GOING to use - still waiting to install guages first so I can take baseline readings - will be to cut the fuel supply line back near the tank, run fuel thru the Purolator filter ID'd above - it's about the size of a beer can - then directly into the Carter 4600 pump, then on thru the stock lines to the stock LP and rest of the system - I'd like to improve upon the fittings at the VP44, but will wait to see what is supplied with the Geno's guages. I'm expecting and assuming that the 6-8 lbs. supposedly supplied by the Carter 4600, added to existing pressure at the VP44 will give me around 18 psi idle/cruise, and hopefully, about 12 psi at WOT with the Comp on a low setting - we'll see! ;)
My setup will be, as nearly as I can tell, pretty much the same as quite a few others are using with good success... I certainly agree, for good engineering, providing a COMPLETE low restriction path COMPLETELY thru the system is desireable - but I've seen that the internal passages in the Carter 4600 ITSELF are considerably LESS than 3/8 - and no telling WHAT the same passages are in the existing stock LP - as well as other points in fuel travel. And until we DO know what ALL the restrictions are, it might be sorta pointless to focus in on enlarging ONE area, when another elsewhere in the system negates our effort to a significant degree.
What I'm doing is at least a start - but probably NOT the end!
;) :D
Gary..
Short of the filter yours sounds a lot like mine. The pressures I stated are about what your looking for so your pretty much on the money with that guess. Let us know how that filter works out. I will probably add one to mine if it seems to flow freely.
Garrett
The presures I see daily.
Idle 16 lbs + gauge only goes to 16
75mph with 2k boat in tow 16lbs comp on 2/3 may dip to 15 on the floor to pass a powerchoke.
WOT comp on 5/5 13lbs @ 40+lbs of boost
I doubt any of us are done yet!
WELL - as posted in another thread - new pump in, stock LP maxed out at idle at about 16 psi - 9 psi WOT - with new pump, 23 psi at idle - not able to take it on the road yet to properly try WOT, but blipping the throttle causes VERY little psi swing... the new pusher pump runs independently of the stock LP so far, and when I switch the engine off, then back on again to keep the added pump running with the engine off, it maintains 10 psi at the VP44 even without the stock LP running - dunno if that's a good thing or not! In any event, the specific filter I am running ahead of the new pump sure doesn't seem to impede fuel flow SO far... :D
Looks like the purolator filter might be the ticket.....
I checked it out on their web site and it looks like it would be easy to adapt. How did you go about mounting it. I have a few ideas in mind already but a hose type clamp looks the easiest.
Garrett
