What's the formula?
Hi Gary,
Curious on the formula as I have the AFE mega cannon that claims 820 cfm. Does that mean for every Cubic foot I have 144 cubic inch of flow? Doesn't seem right as that would give me 118080 Cubic inch of flow??
Originally posted by Gary - KJ6Q
When exposed to more airflow than designed for, paper elements distort, and may actually rip apart - VERY bad in a dirty environment - I actually destroyed an engine in that scenario. Oiled filters like the K&N will stay intact, but the excessive flow of air volume simply FORCES any dirt particles on thru the element material...
Keep in mind that with ZERO boost, our engines suck 360 cubic inches of air per cycle - at 14. 5 PSI boost, that volume doubles to 720 or so - and at 30 PSI, doubles again to about 1440 Cubic inches - and I'm pretty certian you run more peak boost than that to obtain your power ratings - and seriously doubt that K&N pictured is rated anywhere NEAR that figure! Not necessarily a bad filter - just a bad choice for your application - and you mighta been FAR worse off with a paper element - and you're right, ANY similar sized oiled element would undoubtedly have done the same thing!
Get the RIGHT, properly rated filter to match your requirements!![]()
Hi Gary,
