dude, you can be the first to convert yours to have an egr system...
there sure will be no line up to have that done... the OTR/medium duty engines needed to have the egr system to get it past the emissions levels. offroad engines don't have the same levels yet, and the engine in the dodge doesn't fall into the medium duty class [by epa standards] so cummins could use the simpler in cylinder design to get it by the epa ratings...
with an egr system, you oil will get black, and your intake side of the engine will have egr soot/crud build up on them, then you have to have the egr system, cooler, exhaust pressure sensors, mass air flow sensors... and if the system begins to malfunction, you can bet it will real quick [ford 6. 0/vt365 come to mind... ] oh joy...
the externally designed egr systems are mickey mouse. if you really want to believe they are not, go ahead and believe so... with modern technology, that isn't necessary... on many engines now, with variable cam timing, the egr systems have been eleliminated with variable exhaust valve timing... with camless engines, the same will be able to be done...
and if the camless engines scare you, just give up on technology and buy yourself a 12v [and you can get the egr on them in cali versions too, if you want that being it is "such a great system"
