Engine/Transmission (1998.5 - 2002) Why is this...
2nd Gen Non-Engine/Transmission Overhead Fuel Computer?
2nd Gen Non-Engine/Transmission Borgeson Steering shafts
Seems the last 2 times I changed my fuel filter I lose a lb or 2 of fuel pressure. Am I getting air in the line somewhere thats causing this or what. Truck seems to run the same so there is no change there.
PSI drop
I found the same thing happened to me when I changed the fuel filter with less then a full tank of fuel.
I think that changing the fuel filter with a low fuel load is hard on the lift pump when priming the new filter.
Now I fill the tank and change the fuel filter with no more drop in psi.
P. S. I have a gage before and after the filter.
Good Luck
Cliff
I see in another post SNOKING recommended cleaning cleaning pump relay and applying die electric grease. Will try that.
