A word of caution on adding an oil cooler. What would be the negative side of haveing an oil cooler for the 99% of the normal driving miles when not running on a dyno or 1/4 mile drags?
With a totally stock oil system (no bypass, etc) in a 96 5sp, with NO engine fan, Gettmann winter front installed directly in front of the radiator, Air temps have to be over 30 degrees to get oil temps over 175. (Oil Temp Probe in the port above filter housing).
When air temps are below zero oil temps stay at 170 to 175. This is allittle cool IMO already. What is an oil cooler going to do?
I have not been able to get my oil temps over 215 pulling extreme loads on open country. Maybe a 6% MT pass that goes on for miles might do it.
I would think the coolant would be well into the RED before the oil gets above 220.
Would be curious to here what standby or stationary Cummins B engines have to put up with for Oil temps. Lots of extra cooling available in over the road applications.
The Factory oil cooler helps both cool and heat the oil. With the winter front on and 40 - 60 degree air temps, I can get the oil push the oil temps upto 190 by keeping the coolant upto 190. Pull the interfront and oil temps drop to 175 real fast.
IMHO... I think 180 - 190 degree coolant temps and 190 degree oil temps is the sweet spot for best engine efficincy. I get my best MPG if I can keep the temps in the area.
jjw
ND
