When i worked in the copper mines in AZ, i tuned CAT 3516 engines. We used a dial indicator to check lash. This was a top notch set up. I could get ALL the valves dead on. There was no subjective feeling with a feeler guage. So i decided to adjust my rams valves today. i used a dial indicator with magnetic base. 5 and 6 were rough. I needed a smaller guage, but the rest were fine. I spent most of the time finding a suitable place for base to sit and getting that stupid timing pin out. I used a long ratchet and turned the engine over from the damper with right hand and pushed pin with the left. Now check this out. You can actually get screwed up if you dont make sure the rocker isnt centered. they slide about a 16th or so. Stick your feeler guage in there and slide the rocker. Tight... . then loose. So how do you know??? What a pain. Ill now work on a dial indicator set up specially for rams. Ill let you know on the progress. Ray
1996 3500 diesel 5 speed 2wd BONE STOCK 20 mpg
