Wich DVs do I have?
Tire size and RPM
Need More Brakes
My CPL is 2022 and the bosch pump # is 855 and the engine was built in 9/95 and is from a truck with an auto trany. I'm not sure if that makes it a '95 or '96 model because I assume it takes it quite a bit of time to get installed in a truck and get to the dealer. Any body know what DVs are in it?
i would guess they aren't 181's, i believe i have the 131's. i can't remember for sure but i know they aren't 181's. those come in the 215 pumps.
Al at piers told me I have 181s. Now I am really confused. It seems to run well so far with the 370's but I have not had a load on it yet. By the way it is a 180 hp pump. Does this make it a '96 model?
If you send me the engine serial number I can tell you the build date and hp rating. Of course the hp rating is also on that data plate on the side of the gear case.
