Lately, I have thought allot about bombing. This is a new concept to many here, but never the less I have the bug.
So today I did some WOT testing. I was basically trying to determine maximum EGT at a few different boost pressures and RPM's. What I don't have is a baseline to compare to. The reason is that I never thought of doing this before I had my cam put in.
Basically, I would select an RPM in 4th gear that I wanted to test at. Stabilizing at speed, then I would simultaneously press the brake and the go pedal at the same time. Then I would press the go pedal all the way to the floor while holding speed constant with the brake.
Here are my results:
Stock SW 24 psi any RPM ---> could not get the EGT to go past 950F
SW7 24 psi any RPM ---> EGT would climb rapidly to 1000 then creep to 1100
SW7 29 psi 2300 RPM ---> EGT would climb rapidly to 1000 then creep to 1100
SW9 29 psi 2300 RPM ---> EGT would climb rapidly to 1000 then creep to 1100
Raising boost pressure really made zero deference, that I could tell. The maximum boost was produced around 2200-2400 RPM. I did not run any tests over this RPM range. I did run some tests at 1600-2000 RPM, but the EGT response did not vary much anyway from the higher RPM tests so thats all I am going to list.
OK so I would also like to get some baseline data. I was wondering if anyone would mind running this test for me. I would like to get a data set from some one running a pure stock SO five speed. No boost elbows and no performance boxes please. Don't tear your truck up, run short tests 1/4 mile or so at time then let the brakes cool. Reply to this thread and post the results.
Additionally, if any of you Smarty and bigger injector / turbo people would run this test that would also be great. Just contain what mods you are running please. Reply to this thread and post the results.
Especially, I would like to see the Dodgezilla / Smarty SW9 Mach 1. 6, 2 and 4 guys chime in and post there results.
Much thanks;
Jim
Much thanks;
Jim
