60k never wif light, not seen any water during filter changes. Usually fuel up at the same 3 stations, others if it is a long trip. Last winter there was a squeal or whine under the hood when I first started the truck. Could not tell what was causing it, but thought it might have been the CP3, so I shut it down. I drained some fuel from the filter and re-started the truck and the noise was gone. No clue if draining some fuel had anything to do with the noise stopping.
You may want to consider if your aux tank lends itself to condensation. I know of a biodiesel plant that is going to change the 30K gallon tank vents from being open to atmosphere to a nitrogen blanket system because they were picking up moisture from the air.
