Short version: Truck using water for over 12 months with no external signs and no water in oil. Occasional white smoke at start. I finally ran the truck hot and burnt up the motor (pistons seizing to block). Rebuilt motor, bored block, block and head decked, head pressure checked, crank turned, all the usual. All machine work done by the same folks that Cummins south at Chattanooga Tn uses. They are real familar with diesels. They could find no cracks. The truck is still using water( 1 gallon = 300
miles) steam or blowby out the tube, small water particle in oil but not milky and no raise in the oil level. 200 miles Into a 650 mile round trip towing 15k the bearing in the turbo let go. It was a new reman from Dodge total miles on it and engine are 850. This rebuild was a 3 month ordeal and needless to say i'm in disbelief. Total machine work was $1700, parts total including turbo was about $2900 and thats at dealer cost so it seems I now have a fresh $3600 anchor. Block seal is first and when that doesn't work how do I start locating the crack?
