Dont forget Bully Dog'd 50hp injectors. You can also get MACH2 EDMs for around $750. That would require at LEAST a HX35/40 hybrid, maybe twins, though. More fuel doesnt necessarily mean more smoke. A lot of it depends on your pump settings, and air and exhaust set up. The MACH1s I had for a short while smoked about like my stockers (obliterate the car behind me in broad daylight), but would peg the 40# boost gauge, and QUICK- 30+ in 2nd gear, pegged in 3-5. The ones I have now leave a slight haze at WOT.
Ok, on to beating that one in a million 7. 3.
Simply putting that mark on top of the diaphragm at
x o'clock wont guarantee any increase in power. You need to look at the dunce cap and turn the "deep" part of the offset toward the front of the engine. WHile you have the pin out, turn the starwheel (it looks like a gear, dont ask) down a couple rounds to lessen AFC spring pressure. Two turns in on the full power screw is plenty. Time for a set of 50-75hp injectors of your choice. Get a BHAF (or if the dust in your area isnt TOO fine, you could live with a K&N) or aFe ProGard7 filter, a true, full 4" exhaust- turbo back (you'll have to fab your own downpipe), and at least an HX35 with a gated 14cm housing- the 12 gets too restrictive at higher boost/RPMs- maybe even an HX35/40 hybrid (HX35 body and exhaust end, with an impellar and housing from an HX40) or some other modified HX35 or H1C/H1E hybrid.
TUrbo differences. THe main difference you are looking at is the diameter of the impellar pinwheel- H1C-54mm; stock HX35-56mm; modified HX35 (see my sig) 58mm; HX40-60-62mm, depending on app and mods. 6mm may not seem like much, but you figure it is an 11% increase in diameter, 23% difference in flow. (area of 54mm impellar is 2289sq mm; 60mm is 2826sq mm; 2826/2289= 1. 23 or a 23% increase). ANd of course, the smaller the exhaust housing, the faster the spoolup and peak boost, but as you go less than a 16, you run into high RPM/boost back pressure issues, esp with a 12cm. That is why most go with a 16- good spoolup, yet allows for enough top end flow to not choke the engine. Of course, some of the cheaper members just take a Dremmel to the stock 18. 5 and live with a little lag. :-laf
Daniel
