I am the original owner of this truck. It is stock with the exception of a #11 TST plate. The truck has always been able to hit 3000 rpm. This weekend I did a little test to check for de fueling at high rpm. Here are the results. (max boost is 32 psi with # 11 plate)
2750 rpm 32 psi boost
2875 rpm 29 psi
3000 rpm 28 psi
3125 rpm 22 psi
Do you guys and gals think that I would see much of a power improvement if I installed a 3kgsk? As you can see the truck begins to de fuel at about 2800 but its still pulling good up to 3k.
Any advice would be appreciated. Thanks
2875 rpm 29 psi
3000 rpm 28 psi
3125 rpm 22 psi
