Will I have to fmodify the springs with a Mountain Aire 5th Wheel?
Will the real "zzman" please stand up
2001 B2500 W/Auto transmission towing slow
I can't get a straight answer from the dealers as to whether I will have to modify the trailer springs on a Mountain Aire 5th wheel. I have a 3500 4X4 and am concerned about pulling a level trailer. Dealers say the hitch pin is adjustable. Has anyone out there actually pulled one of these and can answer my concern? Really appreciate some reliable information.
2001 Ram 3500 dually, 4:10, auto, SLT+,anti-spin,custom side paint, Custom pin striping,Advanced Thermal Products Sound Blanket Kit, Smittybar nerf step,Geno's stainless wheel well trim, tonneau cover, air dam, chrome monster tip, mud flaps/chrome tips,pyro-trans-boost gauges, Bosch 275 Injectors, Van Aaken, Kondalay TC & Valve Body.
I have had a number of Newmar products. Yes, the hitch on the trailer is adjustable and the 5th wheel hitch is adjustable. Remember, you want atleast a hand width between the top of the bed rail and the coach. The bigger the hand the better. (5 to 6 inches) Most Mountain Aires ride high to begin with. Use at least a 15K hitch. Preferably a Reese "Classic". If your unit is over that, go to the "Classic" 20K. If you need more info, hollar and I will try to help. Happy Camping... .....
2001 2500 QC, ETH/DEE,4:10s, LSD, EZ with elbow(26. 5PSI) Boost/Pyro Guages, 4" Turbo back, BD Brake,Mag-Hytec Cover, Kleen Wheels, Energy Release, 70 gal. fuel, 20K Reese. 25,000 Miles on 01/30/01(RV Dealer)
Millfli, take some measurements of your truck ie. bed rail height and bed height and remember the truck may sit down a bit- compair the height with the fifth- most rigs are parked pretty level on the lot- on almost all pin boxes are adjustable up or down- yes a hand width min. more is better- I've had two different rigs and trucks repaired because the 5th hits the bed- one was in the dealers driveway #ad
Lucky- haven't had to fix my dodge yet #ad
Flipping your axels is about an afternoon job- not hard-- good luck
Thanks a lot for the advice folks. As I have neither hitch or trailer yet (delivery in June) I will take your word that everything will work out. Good to know.
