I'm working on a permanent tap for my fuel pressure gauge and need to know if standard automotive fuel hose will work with diesel fuel. Its in the transfer pump circuit so pressures will be no more than 15 lbs.
The factory has a rubber hose joint in the line between the filter and the I-pump and it looks like standard fuel hose to me.
2001 black dually,4x4, 6 speed H. O. ,loaded up and then some!
