will regular fuel hose hold up to diesel fuel?
Where can I buy Lubegard?
What Depth for Pyrometer Thermocouple?
I'm working on a permanent tap for my fuel pressure gauge and need to know if standard automotive fuel hose will work with diesel fuel. Its in the transfer pump circuit so pressures will be no more than 15 lbs.
The factory has a rubber hose joint in the line between the filter and the I-pump and it looks like standard fuel hose to me.
2001 black dually,4x4, 6 speed H. O. ,loaded up and then some!
Standard fuel hose is for diesel too. Just don't get diesel on your radiator/heater hoses. It eats em up and soon you'll have coolant coming out little pin holes #ad
Larry
1972 Chinook class C with 96/215 5spd, 4/5" exh, 4"BD, MagHytec, 85gal fuel, K&N RE0880, AutoMeter, 370's, BD gov kit, BD afc kit, 16cm, 16%btdc, yada-yada-yada
www.fostertruck.com/cummins
FWIW, I replaced the fuel return line on the 95 in Nov. 99. When I started having hard start problems in Dec. 2000, I knew it wasn't the return line. It was. When I changed it out, it looked the same as the one I changed out a year ago. I had made the mistake of going to the local parts house and asking for fuel line for diesel and trusted there judgement.
On the second repair, after researching past post, I found a spec for fuel lines that Joe D. had posted. Don't recall the numbers but it turned out to be a type fuel line used in high pressure fuel injection systems.
I'd suggest searching for the info and not buying generic fuel line.
Dane, keep in mind that rubber hose will expand and contract with pressure changes, so you might not get a very accurate pressure reading. I wonder if nylon tubing would hold up, you know like the kind you get with a boost pressure gauge? Is nylon impervious to diesel fuel?
Andy
Unfortunately I can't give you a solid answer. I have run across fuel hose that is not recommended for gasoline, but is fine for Diesel. . I've NEVER seen the reverse.
So my answer would be to look for hose that is compatible with Gasoline and you'll be fine.
98. 5' 24v 2500 Auto/3. 54 4x4 SB QC 285-75-16's on Alcoa's. Everything but leather. PIAA 1200's, AMSOIL dual filter relocation system, Smittybuilt Stainless Steel Nerfs, Rhino Liner(Junk), K&N air filter(For Sale)15 year AMSOIL dealer. Time permitting, Soon to include Ultra-lite Pyro,0-50lbs boost, Trans temp in the pillar. Rancho 9000's with in cab adjustment.
