will removing muffler lower EGT's
2001 Auto Trans.
Fuel Filter change intervels???
Finally got my piro hooked up. didnt know that the exhaust temps could move that fast #ad
. empty I can get it up to 1100° if I goose it. I dont know what it will do towing. its at 750° at 75MPH and 500° at 55 MPH. do these number sound normal? will the temps go down is I remove the muffer??
thanks in advance.
2001. 5 2500 4X4, QC, Auto, 3. 54 LSD, SLT, SWB, DD1's, EZ, DTT VB & TC, Westech Boost/EGT gage, Trailer, Camper & Snow plow Packages, White, 35k# Cody Hitch, 20' Gooseneck Lowboy flat-bed Trailer.
1975 Toyota Landcruiser, ARB Air lockers Front & rear, 400 Small Block, SM420 4spd, Stock LC transfer case with 2 or 4 high and 2 or 4 wheel drive Low gears, 15. 5x36" Radial swamper on 12" rims, Custom front & rear bumpers, Roll Cage, Warn 8274 8000# winch, 2. 5" spring lift, 2" body lift. Premier on-board power welder, on-board air, 4-wheel power disk breaks, power steering, Lot of fun.
Any way you can get more hot exhaust gasses away from you engine will lower EGT's. So removing your muffler will lower them
Which flows more easily: stock with muffler removed, or 4" with muffler? Curious for now.
01 QC LWB 5 spd, trailer tow pkg, camper pkg
VA, PS boost module and elbow, PS heater saver
Even better, how about a 4" with no muffler?. I have a 4" exahaust now and i will be removing my muffler next week hopefully so i will let you know if i see an even bigger drop in EGT
Tom, removing the muffler lowered my EGT by about 50-75*, so yes it does lower them but not a lot.
Ray, good question, my guess would be a 4" with even a marginal free flow will flow more than a 3" straight pipe and a 4" with a good muffler will outflow a 3" straight very easily.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S SPA Boost/EGT Rancho 9000's Everything but leather NRA Member Great Lakes TDR Member
