When I read RustyJC's reply on Dec. 14th, I was a little annoyed. After all, I'd spent the money, done the work, driven the miles, kept the logs, and was sure that the wind deflector was saving me money, even if only a small amount. So, I decided to prove, at least to myself, that RustyJC was wrong. On Dec. 23rd I began another round trip from so. Calif to nw Wash via I-5. I did not raise the deflector, kept the speed to 61 MPH and fueled at all the same locations. Everything was as usual, except the deflector was down, not up. I expected that the mileage would be lower.
Well, RustyJC was not wrong, and was probably right; the mileage was exactly the same! So, I kept the deflector down for the return south-bound trip. Again, mileage was exactly the same as the previous south-bound trip when the deflector had been raised to 40 degrees.
I made another round trip at the end of January, this time with the deflector up. Same result; MPG figures were the same as with the deflector down. On March 16th I made another trip north, this time with the deflector up and a steady speed of 64 to 65 MPH. The mileage figures were the same as they had been in February 2006, when I drove the same speeds while towing the same trailer without a deflector.
Between 2-19-06 and 3-20-07 I towed the same trailer, both loaded and empty, a total of 23,414 miles north and south on I-5 between nw Wash and so. Calif. 5,144 miles were with no deflector; 2,296 miles were with the deflector down (a total of 7,740 miles). 15,674 miles were with the deflector up, at angles of between 55 degrees and 35 degrees, but most commonly at 40 degrees. I tried to keep the same speeds over the same stretches of road, fueled at the same places on each trip, weighed the trailer on the north-bound trips, and kept an accurate log with about 15 separate pcs of information. All I can say after that time and mileage is there is not a measurable difference in fuel consumption/savings that can be attributed to the wind deflector.
There MAY be a fuel savings, but the amount is so small it is in the same range as all the other variables -- road surface, terrain, tire pressure, rolling resistance, wind speed and angle, rain, trailer weight, quality of fuel, etc. -- and cannot be measured without much more sophisticated equipment, such as a wind-tunnel. As has been mentioned, there are NO bugs on the front of the trailer when the deflector is raised, so it obviously has SOME effect on the air passing over the trailer. However, whether it lifts the air over the trailer or merely disturbs it so the bugs don't impact and stick is unknown.
IF the wind deflector actually improves mileage as much as 1/2 MPG -- and I have no information to show that it does -- at 12 MPG with fuel at $2. 85/gal I would have to tow the trailer about 33,000 miles to recover my cost of approx $325. 00 to install the deflector; at the same MPG and fuel cost those spending $500 to have a deflector installed professionally would have to tow approx 52,000 miles to recover their costs of installation. If it is only saving 1/4 MPG at an average 12 MPG, those towing distances -- before the cost of installation is amortized -- are doubled.
Having spent the money, built the deflector and installed it, I'll continue to use it when I tow the trailer, based on the possibility that it is saving me SOMETHING; and, it does not appear to be costing me anything (other than the original costs of construction and installation). However, having driven the miles and having kept the figures, in hindsight I would not spend the money to install one; in my opinion the savings -- IF ANY -- are not recoverable in any reasonable period of time.
RustyJC -- YOU WERE RIGHT.
