Window loose?
Wide Eyed Ford Dealer
engine fault code?
my driver's window seems loose. passenger window nice and tight. i guess it's due to more use. i removed the 2 screws inside the handle and the 1 screw by the mirror controle. i could not get the door panel off. does anyone know how? i am still waiting on my service manual. maybe it says in there. any help would be appreciated. btw, has anyone had a loose window? is there an adjustment for this or is this typical dodge after 60k mi?
thanks. scott.
That should be it. You do have to be a little vigorous to get the panel off. Will probably destroy some of the little christmas tree things that hold the panel on. Get a few from Napa just in case. There is a tool you can get to help pull the panel, but a screwdriver works fine if you are careful.
