2nd Gen Non-Engine/Transmission Windshield Wiper Problem
Engine/Transmission (1994 - 1998) Idle speed, road speed at idle, etc
Engine/Transmission (1998.5 - 2002) No start
On a recent trip my windshield wipers went out. Luckily it was the last 45 minutes of the trip; however, it was raining hard and created a real safety issue. I had just stopped for a cup of coffee, and everything was working fine prior to that, although I did notice the wipers appeared to have a slight bind half way through the cycle. When I started the truck and turned on the wipers I got nothing. I checked the fuse and it was blown. I replaced the fuse, turned on the switch, and the wipers looked like they started to go, but never came out of the park position, and blew another fuse. They appeared to bind, and then blew the fuse. I replaced the multifunction switch about a year ago, and the wipers had worked just fine until this latest issue. I'm guessing the motor, but before slapping a part at the problem I want to diagnose the issue. Is there some sort of linkage between the wipers that could be binding up? What is the process for getting at the motor and any linkage that might be there? I suppose another angle might be wiring in the steering column harness. I want to start with the simplest possible solution and go from there. Any suggestions would be helpful. I have checked the search function on the forum and didn't find anything similar to this problem.
Thx, Skip
Skip, I'd check the linkage for missing connectors and foriegn material, first. You need to remove the black cowling in front of the widshield for access, which means you need to remove the rubber hood gasket and the 5 star head, plastic clips. They're not screwed on, they'll have to be popped off, so be careful not to break 'em. Then the black plastic cover should lift right up, with the rubber windshield washer lines attached underneath. This will give you access to what you need, and you can decide which it is, the motor or linkage... .
Chances are, if you drive alot in the rain, it's the motor, looking at your trucks age. Also be sure to look for frayed wires, just in case a mouse has been in there.....
Thank you very much for the information. I'd be surprised if it were a mouse unless it's wearing a life jacket. It rains a whole lot here. I cannot afford to have someone look at it, so now that I know how to gain access I think I can do the job.
Skip
HA! That's funny! Well, I'm sure you can do it, if you have any level of mechanical skill at all. I think it's only three bolts and one plug for the motor, worst case scenario.
