No,no all is good. Just passing along my 2 cents. Hope I didn't offend you either. Out of curiosity,why don't you recommend running closed up if your trucks not running hot? Take care-Casey
after 30+ years in AK,I figured out what works on my vehicles as well as the big rigs and heavy equipment I use to run. I worked all over the State and spent a great deal of time on the North Slope oil fields. (Prudhoe Bay) We covered every bit of coolers as possible,pickups,big rigs and heavy equipment and it was rare to even shut vehicles/equipment down because it wouldn't start till spring. If we didn't cover every inch of the coolers you wouldn't make enough heat to defrost the windshield. If by chance it warmed up enough the corners of the tarp might get moved a tad. I've found on electric fans vehicles don't gain much by covering up the coolers because the fans run too often cooling the motor down.
If your covered and your fan clutch continually turns on and off,for sure uncover a corner. All I'm say in,we've been running fully covered for many moons without problems
I'm not an ice road trucker,never have been. All though I do like the show,it does get nasty on the hwy up there.
The point I was trying to make,there is nothing wrong with running with your coolers closed off. In my area we never see -60*below 0,perhaps -35 below 0
I would like to address your comment:: Down here the intercooler
may be hot even if the engine isn't.
If your monitoring your gauges and know your truck,there will never be a question as to when to run open or closed. I'm trying to think if I've ever had high EGT's without the coolant temp being higher then normal and I can't member. I will give it a try next time I hook on a trailer and pass the info on. :-laf
I know you're not an over the road trucker. Just making a point about
weather conditions.
I think you missed my point about the intercooler. EGT's are not the issue.
Your turbo compresses air which causes heat. The intercooler is there
to cool the air back down again before it reaches the intake. Hot intake
air equals less power. I would guess that the colder the intake air, the
better. Therefore, a stream of air through the intercooler is a good thing.
So, if I customize my center flap with a 7x7 hole I would be prefect as I can get... . So do I had this to the dead center top or bottom? Or a 3x15=45 sq in slot?
