Here we go.......
The transmissions had the required amount of factory lubricant.
The engines DID have horsepower modifications.
They were both Hot Shotters, so they are assumed to be maxed out on weight, or over.
Dodge cannot void your warranty for the coolers or another lubricant unless it is proved to cause the failure.
Do we all agree that our drivetrains are bare minimum for the STOCK Cummins engine? (no brainer there)
So with a modified engine, we are stressing the components beyond what Dodge intended. 50 or 100 hp over stock is easy, cool horsepower, can be had with a stock exhaust and makes an INCREDIBLE improvement in towing. Hills that were 4th gear, are now 5th over, easy. Trouble is, that poor little 5 speed only has 4 quarts of fluid, and it does not matter that the engine can pull that hill, the 5 gear is straining-and making heat.
Some drivers can FEEL when they should gear down--tons of power or not, know what I mean?
Don is right, I would be foolish to tell you Amsoil could have stopped the above shafts from failure.
Amsoil looks better on paper, and could withstand intense heat longer, but we don't know how much better or longer.
The Redline MT-90 looks very good too, but I have not tried it.
What we do know, is the Factory lube was put in this transmission to take care of a stock truck, get Dodge out of warranty with an accepted amount of failures, and hope they trade or buy a new trans after warranty is over.
I believe the Factory lube HAS taken care of the majority of the transmissions out there.
I also believe a lot of guys are reaching the factory lubes limits.
What we deal with on this site, is the few thousand that take their trucks to the extreme.
On other threads, guys seem to be concerned with their lubes being exactly what the factory calls for. But our trucks are no where near what they were from the factory.
How many times do you fix the 5th nut to factory specs before you get the fully splined mainshaft?
I installed a Genos trans filter, and a Mag-Hytec cover when I got my truck, my first BOMBs. I could care less about warranty, as I intended to keep the truck for a long while past warranty. I also bought the best lubricants I could find. These preventitive maintenance items were MY warranty to myself.
If you haul max loads, and have BOMBed the engine, and love blowing past those Cornbinders on the hills, you are killing your 5 gear lube.
If you don't trade every 2 years, you should at least put a set of Fast Coolers on the side, (BTW, I do NOT sell Fast Coolers!) and change your fluid often. I suggest once a year or 30,000 to 40,000 miles.
I prefer another lubricant and an HD input shaft, but to each his own. (Coolers are coming soon, Genos filter will be off. )
Keep in mind your owners manual was designed for the average majority, not Crazy Bombers!
If you plan on keeping your truck a long time, haul heavy loads,with a BOMBed engine, and think the factory "lifetime" fill of 4 qts is plenty, please post your transmission pictures in the future on this thread!J
Just my thoughts, observations from what I have seen the last couple years on this site.
Gene
