All presuming you have a 24 valve having posted in the 2nd Gen section;
TSB
NUMBER: 08-43-99
GROUP: Electrical
DATE: Dec. 17, 1999
SUBJECT:
Central Timer Module Software Update When A Wiper Module Is Replaced
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Central Timer Module (CTM) with new software (EEPROM changes).
MODELS:
1998 - 1999 (BR/BE) Ram Trucks
NOTE :THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH REMOTE KEYLESS ENTRY.
DISCUSSION:
Due to a design change in MOPAR replacement wiper modules, the CTM must be updated with new software in order to allow the wiper module to function properly. This following Repair Procedure must be performed any time the wiper module is replaced... .
snip
Both the base and the high-line versions of the CTM support the intermittent wipe and wipe-after- wash features, but only the high-line CTM supports the speed sensitive intermittent wipe. The intermittent wipe relay is one of the outputs that both the base and the high-line versions of the CTM can control. Each CTM is programmed to energize or de-energize the intermittent wipe relay in response to certain inputs from the windshield wiper and washer switches and from the windshield wiper motor park switch.
For the speed sensitive intermittent wipe feature, the high-line CTM also uses vehicle speed messages, which are received on the CCD data bus from the Powertrain Control Module (PCM).
Both versions of the CTM are mounted under the driver side end of the instrument panel, inboard of the instrument panel steering column opening...
... When the vehicle is moving at speeds at or below 10 mph, the delay time ranges from 1 to 36 seconds. When the speed rises above 10 mph, the delay times are cut in half for a range of 1/2 to 18 seconds. The speed signal is provided to the CTM from the PCM over the CCD bus... .
Diagnostics
The CTM is fully addressable with the DRB III and it is the recommended method for diagnosis. The CTM reports 6 Diagnostic Trouble Codes. All of the inputs to the CTM can be read with the DRB and the outputs can be actuated. If the inputs are OK and the outputs can be cycled with the DRB, the problem is usually the Central Timer Module.
