Wiring for Ham Radio, etc
Acceptable DB's and flow?
Summit high beam wiring harness
I would think that the firewall would be the same no matter which trns. Mineis auto 2001 2500 and on the drivers side is a large rubber grommet that I ran my wire and coax thru.
Nathan
Bob, I can't say myself, but there is a guy who posts as "drivers mopars" here who has I think a 93 dually that is very much into Ham and other types of radios. He may have a suggestion for you.
Tom
Get outta the way: The Cummins is Cummin'!
Tom Golden
Godzilla: Patriot Blue 2001 2500 SLT QC 4X4 LWB ETH/DEE, Tow & Camper packages, 3. 54 Ltd. Slip, 4 wheel disc ABS, Isspro EGT/boost gauges, black SmittyBilt nerf bars, K&N RE-0880 & pre-filter, no silencer ring, TDR decal, Jack holiday antenna ball
2001 Zinc Yellow SVT Mustang Cobra on order
NRA Life/CRPA/El Dorado #26 F. &A. M. of California
My 97 has the grommet for the main harness so I ran my antenna and power wires through there. But on some 2m frequencies, the ABS lamp will flash when I transmit. I am planning to drill a hole in the firewall for the antenna cable (RG58) one of these days.
My wife's 98 had such terrible 2m noise problems that I started with the grommet but drilled the hole in the end. It helped but the only way I could cure the noise problems in the 98 was to make a copper shield for the ABS controller under the hood. What I should do is take the 98 to the dealer and show them the noise problem, but I don't have the energy to fight DC.
Drill the hole, if you have a 98 or later.
1997 4x4 CC 5spd, CPL1553 pump, Horton fan, Sport headlamps, Optima RedTops, 98 shift levers and console, RS5000 shocks, Yaesu VHF radio, and BCT7 scanner in the overhead console... N7DAL.
I ran the coax under the passenger side door moulding, to the rear of the cab, and drilled a 3/16" hole, so it could exit under the cab. Then ran it along the frame and up into the bed thru the drain hole in the corner of the bed. Seal all of the entry/exit points with some RTV (on the outside to prevent any rusting). My Antennas are mounted on a camper shell which I never remove.
Frank - K7SFN
Frank Dziurda - K7SFN
Carson City, Nevada
'99. 5 2500 4X4 6-Speed Quad Cab LWB 3. 54 LSD
Anyone know the best way to get power wiring into the cab of a 2001 6spd? On my 98 Auto the gasket where the clutch is now was a great entry point. I can't seem to find any empty grommets on the new one. Don't want to drill but that might be my last resort.
2001. 5 White 3500 Quad Cab 4x4 Sport SLT+, ETH/DEE, 4. 10 Anti-Spin Axle, Camper Special Group, Trailer Tow Group, Tekonshs Sentinel Brake Controller. Preparing to add Guages, Line-X, 20. 5 Pullrite Hitch, DEE-ZEE FX Running Boards, Exhaust Brake, ICOM 706MkIIG HF Radio (maybe more later). Pulling 99 Hitchhiker II 30RK fiver and ordering 2001 Alpenlite 35RK fiver.
Ham Call: AF9W/7
Frank's coax routing is the best way. On the power lead to the battery, you should have a silicon rubber hole cover on the firewall to the left of the steering column. Just punch a hole with an ice pick, run the 14 gauge power lead out to the battery. The rubber will seal back around the wire nicely. Be sure to ground the rig as close to the radio as possible. I used the transfer case shifter hole in the cab floor for my ground. No noise or RFI problems at all.
Ron
'99 QC SLT 4X4, Forest Green, long box, camper/trailer pkg, 3. 55 axles, auto, CD/cassette, power seat, heated mirrors, HD xfer case, Two meter Radioshack ham transceiver (license KC7MME),Proud member of the vast right wing conspiracy!
'98 Arctic Cat 300 4X4 ATV
'00 Honda Recon ATV
'99 Grand Cherokee
NRA Life member
"Bible thumping" Rush Dittohead!
