wiring harness?
start then stalls
Antifreeze Smell in Cab when running floor heat.
I have a 07 3500 with 108,000 miles. It has been a great truck. Lost an injector wiring harness last year in Kansas and replaced u joints last year also. Other than that has worked hard for me. Last week the check engine came on and truck started running poorly(no power). It corrected itself a few hours later, and few on/off cycles later. The check engine remained on, but it ran fine. Had my mechanic look at and he did a cylinder diagnosis to all 6. He pulled a cylinder 3 misfire code(I am pretty sure that is what he said) He said all 6 were at 100%. He cleared the check engine and sent me on my way. Today the same thing has happened. Check engine on, but truck running fine after a short spell of running poorly and multiple on/off cycles. I have obtained the codes from the dash and they are p0204 and p2149. I have found the codes on-line and what I found states 0204 is fuel injector 4 circuit and 2149 is fuel injector group 2 supply voltage circuit. My question is if this is multiple problems or another wiring harness. I am also wondering if it is a wiring harness again would it be worth while to replace all the harnesses to all the injectors while the valve cover is off. I plan on driving/owning this truck for a long time. Thanks
wiring harness
Thanks, If I had my harness replaced once before this entire unit was replaced because as you show it is a complete assembly. If so I wouldn't you think it should not be failing again so soon. Is something else potentially going on to make this harness fail again?
Just a reminder the engine warranty dose not start until the end of the 3 year 36,000 mile warranty. That being said the engine is covered to 136000 or 5 years which ever comes first. That is found in the diesel book of the owners manual. Hope you get your truck fixed. It is a drag when they don't run right.
I got this info from the dodge web site hope this helps. I saw the section you referenced but the part on diesel coverage is down a little father on page 8
C. When It Begins
The Cummins Diesel Engine Warranty begins at the
end of the Basic Limited Warranty, on either of the
following dates, whichever is earlier:
• the date your truck has been in service for
more than 36 months; or
• the date you've put more than 36, 000 miles on
the odometer.
That not what the official Website has. Contact Dodge they have officially acknowledge That some warranty Manual are miss-prints.
The tricky part is WHICHEVER IS EARLIER. How would they know when you put 36k on The OD. You would have to bring it to the Dealer on that Date?
