Guys,
Just showing off my new ARE cap and the wiring job an ARE distributor did while installing my new ARE MX series cap. Have not had a chance to use the cap but as they described the wiring work, I knew I'd at least be checking the work. It has a high stop light and interior lights for the rear and each side windows, "windoor".
So far the cap seems just great, but look how they probed the wiring right at the plug probing for the stop light circuit. It would have been easy to remove the plug from the lamp housing and test the exposed terminals for the stop light circuit w/o any probing. But that darn unsealed wire tap has to go. And then they probed the 7 way right at the plug. They did nothing to seal the holes in the insulation. And probing right at the plug does not allow hardly any chance to repair corrosion damage I have an auxiliary back up light system that has a separate hot circuit and powering a relay. Easy to connect to if they would have asked. I'm kinda fussy about electrical circuits and I use my 7 way including the charge line that they tapped into when I tow.
So, what ya guys think about the probing and leaving the wires with holes in them?
I already started the repairs to the probed insulation. And they didn't even tighten the ground screw that they installed.
I do like the cap.
Gary
I do like the cap.
Gary
