Details here: TDR Privileges
Does anyone have the how to on being able to put the transfer case in low and just have it affect the rear wheels... . for manuvering a load on dry pavement?
I purchased the solenoid from www.eaglecontrols.com it is a Numatics L01SA459B. This is a very small 12v solenoid that is used with a lot of the exhaust brakes.
To install, find the vacuum line header along the top of the fire wall just above the fuel filter. You will find a vacuum line going down to the transfer case. All you have to do is place the solenoid in this line, which when activated will block the vacuum from going to another solenoid that is activated when you pull the transfer case shifter in.
So when you have it installed, you turn the solenoid on, and then pull the shifter in, and walla!!
It works very well when backing a heavy load, or when you want to creep over rough terrain, and don't need 4x4.
I hope this is at least clear as mud! It's really pretty simple.
