i just got my AUTO METER PHANTOM gauges and i got everything done,
exhaust manifold drilled and tapped also my intake manifold drilled and tapped
lighting wires done, my question is-- there is three gauges , boost ,pyro,trans temp. trans temp has three wires 12v+, negative, and sender wire . pyro has two wires 12v+ and negative do i connect the two 12v+ wires together and then tap into the lighter switch or wher else , also
the negative wires can i connect them together what do you think? any imput would be greatly appreciated .
_______________________________________________________________
2004,5 ctd HO 325/600 2500HD 4x4 48re 3. 73 f/er wanderes reese hitch dark grey k & n intake rancho shocks BF GOODRICH tires westin step bars
