O2' 3500 4x4 welding rig w/ Juice & attitude, FASS II this is a work truck that is DRIVEN. I Just blew a head gasket and am replacing with a OEM Marine grade W/ ARP 12mm studs. I have been told that with my weight (10,600 lbs. ) being driven on a daily basis running Colorado & Wyoming hills that I am running in a negative delta, and that even though my boost is under 32psi. ,internally the pressure is much greater. They strongly suggest a stage II Garrett Powermax turbo and pretty much promise that this will eliminate my Negative delta. It should also improve mileage and make blown head gaskets do to negative D a thing of the past.
Any in sight would be greatly appreciated. Oo.
Please respond ASAP
Please respond ASAP
