Adjusted the bands and installed the APPS noise isolator from Genos last month to cure the 45-50 mph trans lock up and the unlock issue.
Towed my boat to Laughlin from Phoenix last week with no issues. While there, the trans started to resist going into 3rd gear unless I was off the throttle.
Got it home by going very easy on the throttle and letting the cruise control do the work. Adjusted the APPS to .495 per from .463 per the white tag.
No codes ever thrown. Still have the same problem. Fluid level is fine and looks and smells good. Trans running 150 -160 degrees while towing.
I can manually shift thru all gears with the column shifter. Any suggestions?
Thanks in advance.
Jwats
PHX
Thanks in advance.
Jwats
PHX
