Engine/Transmission (1994 - 1998) won't go into gear while running
went through the past posts.
5spd transmission won't shift will the engine is running. posts suggest pilot bearing
truck was shifting fine in the morning, does this happen quickly?
if I put it into gear and let it run would it loosen up?
just go the truck new centerforce clutch and rebuilt transmission 50k ago.
not looking forward to taking this thing apart.
clutch works fine
If the pilot bearing was bent a little on instalation it could have caused it to go bad with only 50k. Although that is weird that it worked in morning and not afternoon. Will it shift into any of the gears or have you tried other than first gear.
