i know this is hard on a stock trans. since i put the comp on i could start to feel this problem. i do not know what my fuel pressure is, no guage. how do i check the fuel pressure on my truck since i have the fass system on it. it replaced the line going to my pump and the check valve attached to the stock line. is the only way through an actual in cab guage. i have heard about the tourque limiting sensor that is built in to the 01 02 computers on auto, which defuels it right? but my truck will do it extremly bad form the line and through out the gears, most noticeable in level five, but all around the 2000rpm. graphic man, did the bd or smarty fix your problem or was it a vp44? tim, thanks for the advice about the trans, next step billet input shafts and converter, heavy duty clutches, and re-worked valve body, if i ever get this problem solved.
nathan
