Wont shift into OVERDRIVE
fan clutch
New head studs - low power?
I have an 04 2500 5. 9 single wheel. I purchased this truck brand new in oct. 03. This rig has only 70k miles on it and has been severly pampered. Less than 10k miles ago i had the second gear clutchs replaced and the rest of the trans freshened. At that time i had them do the typical shift kit to firm up the shifts along with a nice billet converter(tighter than stock obiviously). I have love the results of this mod so far!
2 months ago the trans began acting funny... ie, not always shifting into overdrive like it should. I pulled the valve body down and replaced the notorious solinoids within. When i reassembled, i went to test drive... . STILL no overdrive! I pulled over, pulled out the bullydog power pup extreme program and put it back to stock programing. . Took off and... . bam... went right into overdrive. ! I left it on the stock program for a few days, then i just couldnt stand the lack of power anymore, i put the extreme program back in. I had no one ounce of trouble until this last weekend. I was running around town when all of the sudden... no overdrive again!!! Once again i downloaded the stock program again thinking that would fix it... . nope, still no overdrive!! I left the truck sitting at home the remainder of the weekend with the batts unhooked. Monday morning, hooked the batts up... . STILL no overdrive!! I feel confident this is not a mechanical issue with the trans, but yet either a solinoid issue or a computer issue.
Anyone have any advise??? This is my third cummins with an automatic. For some reason it seems im continuously replacing these dang solinoids!! Whats the deal??? BTW... IM done with bullydog... not impressed. Gonna go smarty with twins hopefully... . but i gotta get it to shift first!!
Any help appreciated. . Thanx
