I bought an adjustable trackbar a couple of years ago from SSI. Even when new, i noticed some amount of play at the lower connection (axle); no movement at all was seen at the frame connection. Over the weekend, i was under the truck and noticed there is considerable more play (movement) at the axle connection; no play seen at the frame side. I removed the trackbar to inspect the bushings and did not see any wear to the inner sleeve, bolt or axle tabs. I am thinking the rubber is just too weak. My question is, will the poly bushings Geno's offers (i believe they are from Luke's) work in this trackbar? Or, does anyone have other suggestions? Thanks.
