You can simply remove that screw. However, it order to gain from this you will have to tweak the throttle linkages to allow the throttle contol lever(s) to move (rearward) enough to gain anything above much over a couple hundred rpm's.
This process can be lengthy and I'll not take time to go into full datails at this time unless you spacifically ask.
Simply LOOK at ALL the throttle levers and how they move. You'll soon discover that there are a lot of built in limiting factors you'll have to address. Nuff said.
