Would injectors wake this truck up???
A/C quit how do I test it?
transmission Temp
My brother has a 2002 3/4 ton 5-speed. After driving my 95 model, he has decided to start bombing his new beast to keep up with me. Would bigger injectors be a good first bomb, or what about a powermax2?? What do you guys think, lemme know
Willie
Almost anything will!
The cool thing about the Cummins is that there
are so many different ways to enhance the power
output.
Easiest way is a Fueling Module, like Edge EZ,
PMax, etc. That's usually the first step.
Going to a set of injectors like 275's is a
good step after the box is installed. More than
that and you'll be upgrading the stock clutch.
But like Deezul1 said, get the gauges first!
Most important is EGT, pre-turbo the probe.
-Chris
Originally posted by CUMINNTSTRKN
guages and a edge comp and you will have your hands full!!!
jim
Yep!!! The Comp is the way to go. That way when the bug gets a good hold on him he won't need to swap it out.
Gauges, PE Comp
later... Stage 3's, ex, turbo... . the list goes on.
