Would like to replace all of my fuel lines....
Intake heater needed???
BettyAnne asks:.......
Upcoming project.....
I would like to upgrade my fuel lines from the tank all the way to the front with heated ones. How much would I need? Would there be any reason to go to a larger diameter hose? What sort of fittings go into the filter and the pump? The problem is that it comes in standard lengths. So I willl have to deal with extra hose as a consequence.
Any ideas????
I've read in the second gen forums that a larger diameter line will cause the engine to have a lope, sort of like a cammed up gasser, but it can also lead to dying problems at an idle. Don't recall if it had any hp gain or not.
AJ
there should be no problem going to a bigger line as long as you can keep the pressure from the tank to the pump the same they do not draw that much fuel to cause the pressures to be low with larger lines it should in all axctuality be better for them.
