Seems to me that there used to be a sticky for these kind of things, and I think I wrote one for this. Looks like they got it covered for you. Take your time.
One piece of advice...
I have done about 40 of these. I learned to kill two birds with one stone as I was buttoning up the job. I leave tightening the injector lines for last, and I direct wire the transfer pump (TP) to the battery and as the TP is running, I wait to see which injector lines at the head start bleeding. Once I get good fuel flowing (usually 2 at a time) I tighten them down, rotate the engine 120* (22mm socket on the alternator bolt) and wait for the next 2 to start bleeding.
Once I get all the lines tightened down, then I install the TPS sensor, rotate the engine, air hat, rotate the engine, and so on. I leave the pump running and keep turning over the engine by hand until I am ready to start, get the TP plugged back into the truck, and I rarely have more than 5 seconds of crank time, and do not have to crack open any injector lines. Clean off the fuel from the bleeding process, take a test drive and then check for leaks.
