I need some direction. I bought a plastic tank from a 89 Ramcharger that I am going to use as an auxiliary tank. After installing the tank in the truck, how do I go about setting it up to transfer fuel to the primary tank?
Initial plans were to install a hose into the tank, to the transfer pump, possibly to a filter, and then to the primary tank. What I don't know is: Can I eliminate the fuel sending unit from the ramchargers tank? Can you take it off, and still keep the lid of the tank? Also, is there a port on the top of the primary to dump the fuel into, or is there a better way of doing this.
Another thought was to install a door on the side of the bed and just install some kind of valve/switch to go from one tank to another, but I really dont want to install the second door on the side of the bed.
All options considered.
