Y2K auto shift lever problem
Cruise control quits.......
DC Arbitration- How Much A Pain????
Hi guys,
I have a problem with the shift mechanism on my Y2K auto. #ad
The "drive" position on my shift lever has a little bit of slop. When I shift to drive, if I move the shift lever until it hits the stop, it sometimes isn't really in drive. I'm not sure if it is actually in second, or if it's just the overdrive that doesn't work. Anyway, if I move the shift lever up about ¼ of an inch, it seems to slide into the drive position, and it works fine. I removed the cover from my steering column today, hoping to find a way to adjust the drive position stop up slightly. Unfortunately, the stop is a small slot in a rectangular piece of metal that is riveted (I think) into place on the steering column. So there appears to be no way to adjust the shift lever from the steering column end. Is there an adjustment on the transmission? Is this a common problem? I really dread the thought of bringing my truck back to my dealer to have them "try" to fix it. I already brought the truck in once for this problem, and the tech blamed the guy who installed my Viper remote starter/alarm (wires on the steering column). So then I brought my truck to the alarm installer, and he said that he didn't see anything he did that could cause my problem. I appreciate any help you guys can give me.
2000 2500 Quad Cab, SLT, 4x4 Auto, 3. 54 LSD, Forest green two tone paint, all options except leather and CD player, Fisher 8 foot minute mount plow, Dodge Sill Guards, Dodge mud flaps, Dodge bug deflector, fog lights (installed myself), Line-X bedliner, Back-Rack ladder rack, Viper remote starter/alarm.
Originally posted by Bob Wagner:
I have the same complaint that the shifter can be out of position in drive
Had the same problem on mine after DC replaced the kick down cable, took it back & they adjusted it at the transmission selector lever at the trans. works good ,right & tight in the detents.
GOOD LUCK
2K,BROKEN ISB :( 2500,Laramie +,Quad,4x,"slushbox 250 RPM drop WOT shifts",everything cept leather and clearance lites, reese 15k 5th slider, LAVERNGE BULL BAR,WESTIN NERFS,
pullee #1 26' Arctic Fox 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA,VFW,SASS
I've got the same problem. Also had it in my 98 1500. I've just been putting off having to take it to the dealer.
Steve
Intentionally Left Blank for the Dodge Web Nazis
just adjusted mine this morning, there is a small wheel that adjust the linkage under the steering column, it is white.
TAZ... 2001 2500 SLT+ 4X4 Auto ETC Cummins, LSD 3. 54,Quad Cab, Long Bed, Agate Leather, White/Driftwood Exterior, Sliding rear window, Camper Special Group, Towing Group, Cab clearance lights, Diesel Dynamics Stage-3's, DD Boost Module,SPA-Technique Digital Dual Gauges (Pyro/Boost, Trans pressure/temp) Aux. Backup lamps. BNM 5th Wheel Hitch, Additional Body Molding on Bed. BD Torc Loc, BD Pressure Loc, Line-X bed-liner. DTT's TC & VB. Pac Brake
2000 32' Aljo Triple Slide 5th Wheel.
http://www.ramtaz.com
Add on's to come: Power Edge Box,and any other Ram Runner required modifications...
MCrossley, The white adjuster wheel on the steering column only adjusts the position of the indicator. My problem is with the shift lever itself. Thanks anyway.
Greg
